VFlav
3 years agoFinal postfit netlist check failed ; Internal Error: Sub-system: FDRGN
Hey, I open discussion to report Final postfit netlist check failed. Quartus compilation crash at the end of fitter process. Problem Details are available below for more information. As recommand...
- 3 years ago
Thanks for your help
Unfortunately, I'm not authorised to share my project.
To complete the compilation, I had to delete DDR4 communication with FPGA.
This issue can be solve from your side with this modification.
RichardT_altera
3 years agoCould you upgrade your project to the latest Quartus Pro version 22.3 and see if the internal error(IE) resolves?
If the IE still occur, please help to share us the project .qar files as we will need to duplicate the error.
Without the error duplication from our side, it would be hard to find a workaround/solution.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
