10 years agofile read and write function fails to execute in functions
Working on migrating old code into the next FPGA generation. That means the code worked fine over the last twenty years and had a few migration since utilizing non Altera FPGAs and tools. Now I am tr...
10 years agoby the way... this is normal path when you migrate to another newer version.. what is the initial version that you are using correctly? maybe stay with that version unless you want to spend some time to fix those incompatibility problems
