9 years agoFile not simulating with ModelSim-Altera
Hello guys, I have the following two projects. The first one Simulates perfectly in modelsim-altera, but the second one does not show output. I want to know where is the problem in the second one??? ...
9 years ago --- Quote Start --- Thank you very much, I took your advice and now the design works perfectly. But, I have one last question if you don't mind. I have thought about the program and now I want to divide the clock by (2,3,4,5,6,7....) rather than (2,4,6,8,10,12....) what can I do now?? The counter is integer, so when (the counter = 2 => divides by 4), when (counter=3 => divides by 6 and so on. But, suppose I want to divide by 3. I can't say when counter = 1.5 because it's integer. Thank you for your help. --- Quote End --- Hi I never tried to implement this kind of clock divider. Why do you need such clock divider? I think in this case you will need to implement two counters. One trigered from rising edge second - from falling. Then you have to check when total count value of both counters rech your div value eg. 3. As I said before never tried this myself, just my thougts.
