9 years agoFile not simulating with ModelSim-Altera
Hello guys, I have the following two projects. The first one Simulates perfectly in modelsim-altera, but the second one does not show output. I want to know where is the problem in the second one??? ...
9 years agoFirst of all, thank you very much for your code. I checked it and it works perfectly. As for why I use the falling edge of the clock, it's because it makes the comparison between the clock and the output easier. Now, do you think I could extend your code to divide by (4,6,8,......)??? Thank you for your help really.
