12 years ago
FIFOed altera UART won't build with Qsys from Quartus 14.0
The FIFOed UART from
http://www.alterawiki.com/wiki/fifoed_avalon_uart
Won't allow Qsys to generate the system. It gets the error:
--- Quote Start ---
Info: fifoed_tbus_485: Starting FIFOed UART Generation
Info: fifoed_tbus_485: exec perl -I . -I C:/altera/14.0/quartus/sopc_builder/bin/ -I C:/altera/14.0/quartus/sopc_builder/bin//europa/ -I C:/altera/14.0/quartus/sopc_builder/bin//perl_lib/ mk_em_uart_sa.pl
Error: fifoed_tbus_485: couldn't execute "perl": no such file or directory
while executing
"exec perl -I . -I C:/altera/14.0/quartus/sopc_builder/bin/ -I C:/altera/14.0/quartus/sopc_builder/bin//europa/ -I C:/altera/14.0/quartus/sopc_builder/..."
--- Quote End ---
Saying it won't run perl. It does build for 13.0sp1. Thr output Qsys message shows.
--- Quote Start ---
Info: tbus_485: Starting RTL generation for module 'burst_master_sim_tbus_485'
Info: tbus_485: Generation command is [exec C:/altera/13.0sp1/quartus/bin/perl/bin/perl.exe -I C:/altera/13.0sp1/quartus/common/ip/altera/common/perl/5.8.3 -I
--- Quote End ---
As after exec the correct destination is pointed to for perl.
i.e.
instead of exec perl -- for 14.0
Any solution for this for 14.0?
    I have the same exact problem so a solution or workaround would help.
    Also, version 14 does not have the "Run SOPC Builder to Qsys update" feature. Does anyone know the workaround for this?
    --- Quote Start ---
    i.e.
    --- Quote End ---
    In "fifoed_avalon_uart_hw.tcl" (~line 278), change "set perl $qdr/bin/perl/bin/perl.exe" to "set perl $qdr/bin64/perl/bin/perl.exe"
    Do a system refresh (F5) and generate in Qsys. Not tried in 14.0 but works in 14.1
    HTH
    B
    Thank you for that however I have created our own proprietary FIFO'ed 16550 compatible UART.
    I will give that a try out of interest though.
    baz32767,
    I made this change that you suggested and I was able to generate in Quartus 15.0 - Thank you so very much !!!!!
    Does anyone Know when the next release of this IP will be to work with Quartus 15.0 without having to make this change ????
