8 years agoFIFO Works fine on EDAPlayground but not Quartus
All, The following code works fine and as expected on EDAPlayground, but Quartus has an issue with it. I get the ERROR 10028 Can't resolve multiple constant drivers for nets w_addr and r_addr. ...
8 years ago --- Quote Start --- you need to insert the statements: w_addr <= 0; r_addr <= 0; so as to reset them in same top two processes. --- Quote End --- I guess I don't understand. If I reset them in each posedge process, then they will always be zero, and the array will not increment. I do set them to zero in my nrst section. Keith
