13 years agoFIFO memory- code help
Hi! I need to make a FIFO memory in VHDL (XILINX) and I tryed a lot, but I have some problems and I can't understand what's wrong! :(
I need to make PUSH and POP and to say when the memory is FULL or EMPTY! The PUSH part works but not very good.. I need to wait for 2-3 CLOCKs to PUSH a value, and the POP part doesn't work but if i make a lot of POPs the memory is EMPTY (that's ok) but it doesn't write any value! Can you help me please? (PS. sorry for my english, hope you understood!)
library IEEE;
use IEEE.Std_logic_1164.all;
entity FIFOMXN is
generic(m, n : Positive := 8); --m is fifo depth, n is fifo width
port(RESET, WRREQ, RDREQ, CLOCK : in Std_logic;
DATAIN : in Std_logic_vector((n-1) downto 0);
DATAOUT : out Std_logic_vector((n-1) downto 0);
FULL, EMPTY : inout Std_logic);
end FIFOMXN;
architecture V2 of FIFOMXN is
type Fifo_array is array(0 to (m-1)) of Bit_vector((n-1) downto 0);
signal Fifo_memory : Fifo_array;
signal Wraddr, Rdaddr, Offset : Natural range 0 to (m-1);
signal Rdpulse, Wrpulse, Q1, Q2, Q3, Q4 : Std_logic;
signal Databuffer : Bit_vector((n-1) downto 0);
begin
prc: process
begin
wait until rising_edge(CLOCK);
if WRREQ='1' then
Wrpulse<='1';
Rdpulse<='0';
elsif RDREQ='1' then
Rdpulse<='1';
Wrpulse<='0';
else Rdpulse<='0';
Wrpulse<='0';
end if;
end process prc;
Fifo_read : process
begin
if RESET = '1' then
Rdaddr <= 0;
Databuffer <= (others => '0');
elsif (Rdpulse = '1' and EMPTY = '0') then
Databuffer <= Fifo_memory(Rdaddr);
Rdaddr <= (Rdaddr + 1) mod m;
end if;
end process;
Fifo_write : process
begin
if RESET = '1' then
Wraddr <= 0;
elsif (Wrpulse = '1' and FULL = '0') then
Fifo_memory(Wraddr) <= To_Bitvector(DATAIN);
Wraddr <= (Wraddr + 1) mod m;
end if;
end process;
Offset <= (Wraddr - Rdaddr) when (Wraddr > Rdaddr)
else (m - (Rdaddr - Wraddr)) when (Rdaddr > Wraddr)
else 0;
EMPTY <= '1' when (Offset = 0) else '0';
FULL <= '1' when (Offset = (m-1)) else '0';
DATAOUT <= To_Stdlogicvector(Databuffer) when RDREQ = '0'
else (others => 'Z');
end V2;
