14 years ago
fifo megafunction simulation problem
hi there,
i'm new in fpga world and i just started playing with megafunctions, and already encountered problems.
i'm trying to adapt a working structure on xilinx to altera(the project isn't mine, i just have to adapt it to altera, so i can learn more about this job).
i'm using a module with different clocks for read and write, asynchronous reset, and only the rdempty signal. when i simulate the entire module, after inserting some data's, i try to read them, but the "q" signal is zzzzz :(
i also noticed that the rdempty signal is in a hi-z state.
i replaced the megafunction fifo with a manual made module, having the same properties(different clocks, rdempty signal) and it works properly.
Any ideas? please
    --- Quote Start ---
    hi there,
    Any ideas? please
    --- Quote End ---
    Did you fix your problem? I have similar problems since my q is also Z. Just to note, Altera-ModelSim only supports Altera's Megafuctions, if you are using any Xilinx IP on it, it will fail.
    I'm using a .tcl file for simulating. To work, you'll have to add the altera_mf library to the simulation. I've used the following code line:
    vsim -L altera_mf -t ns work.test_fifo
    --- Quote Start ---
    --- Quote End ---
    I think I do add the altera_mf library.
