12 years agoFIFO IP Full and Empty Simultaneously
Hello, I have DC FIFO I am working with in my design, and the FIFO is constantly showing it is both full and empty at the same time. The FIFO fills up with sampled and analyzed data from an AD...
9 years agoIn the end, I used the DCFIFO megafuntion and hooked up the same clock and reset to both clock and reset ports. It worked without any of the problems mentioned above, at least so far. If it breaks, I will post an update so this is not misleading.
