12 years agoFIFO IP Full and Empty Simultaneously
Hello, I have DC FIFO I am working with in my design, and the FIFO is constantly showing it is both full and empty at the same time. The FIFO fills up with sampled and analyzed data from an AD...
12 years ago --- Quote Start --- I had (and still have) a problem with Fifos and Quartus on some projects. On 3-4 projects that I currently maintain, there are a few fifos that have the same behaviour that you describe. The usedw signal is correct, but not the full and empty signals. The only workaround that I found was to delete all generated files, including the db and incremental_db folders, and compile the project from the beginning. Then the fifos work as expected. You could try and see if you have the same results. --- Quote End --- Oh, dear! I will try this. I have too many trouble with FIFOs. Just a moment ago, a SCFIFO has the full flag set but usedw all zero.
