12 years agoFIFO IP Full and Empty Simultaneously
Hello, I have DC FIFO I am working with in my design, and the FIFO is constantly showing it is both full and empty at the same time. The FIFO fills up with sampled and analyzed data from an AD...
12 years agoIt tests the personality of your design, as it must decide if its empty or full. Wait, I think that's the half-empty and half-full signal. :)
Naturally, that shouldn't occur. Do you have the read and write protection circuitry on? They are by default, but if you turn them off you can write when full or read when empty, which can cause the FIFO to wrap-around and do all sorts of weird stuff.
