FIFO configuration and Read
Hi.
Can anyone help me how to configure the fifo in max10 for below requirement.
So i'm getting stream of rgb pixel data in single channel one by one each having 12 bit width and 300 depth. i want to write the rgb data into separate FIFO and while reading from FIFO i want to read rgb parallel to convert 12 bit data to 10 bit and make it 32 bit rgb data. can i get any help for this.
i studied max10 memory FIFO ip settings user guide but not getting how to do this.
thanks in advance
- RichardT_altera
You can use DCFIFO_MIXED_WIDTHS, but the FIFO width ratio is restricted by the type of RAM block (MAX10 M9k), and in general, are in the power of 2.
Reference: http://www.hlam.ece.ufl.edu/EEL4712/LectureNotes/MAX10-EmbeddedMemory.pdf#page=53
- m_kumar
Thank you sir.
- m_kumar
Due to small variations in health i'm not in office once done with the task i will update result sir.
- RichardT_altera
How are you doing? Do you able to get any result from the latest reply?
