SKhan10
7 years agoFGPA Reset Issue
Hallo Please have a look at the attached bdf file. we used the reset circuit as recommended by Quartus. Still the design does not get reset properly every time when the reset is pressed. Any sugges...
KennyT_altera
7 years agoLooking into how you write the constrain, did you make sure that the value 0.5 is the right value get from the board? Did you check you have timing violation?
Also, did you run a simulation test in Modelsim to make sure that the functional is correct?
