Fault Injection Intel® FPGA IP Core with Cyclone 10GX is not working on Quartus II Pro Edition
Evaluation period allows you to use any Intel IP for starting 30 days without license without programming file support(time limited programming file) once the Evaluation period over, you need to purchase the license through SSLC to generate unrestricted.
https://www.intel.com/content/www/us/en/programmable/documentation/esc1425946071433.html#mwh1410890914743
Even you can check"1.2.2. Checking the IP License Status" from link below,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_intro_to_megafunctions.pdf
you can apply for separate license for fault injection IP Core using self service licensing center(SSLC),
https://fpgasupport.intel.com/Licensing/license/index.html
Vicky
Hi Vicky ,
Thank you so much for your answer. Unfortunately, with the 30 days trial the Fault Injection Debugger is not working. Do you know if the only way to obtain just the license for the Fault Injection Debugger (not the IP of Fault Injection ) is to buy the unrestircted license? We also try to ask for a licence in the University Program, but we did not receive any answer.Best regards,
Francisco
