NSona1's avatar
NSona1
8 years ago
Fatal: (vsim-3807) Types do not match between component and entity for port "dataout".
The error shown is-
The following is the error shown
** Fatal: (vsim-3807) Types do not match between component and entity for port "dataout".
# Time: 0 ps Iteration: 0 Instance: /lineartau_1_vhd_vec_tst/i1 File: lineartau_1.vho Line: 86
# FATAL ERROR while loading design
# Error loading design
The code is-
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity lineartau_1 is
port (clk:IN std_logic;
dataout:OUT integer range -128 to 127);
end lineartau_1;
architecture arch_sine of lineartau_1 is
signal i:integer range 0 to 31:=0;
type memory_type is array (0 to 31) of integer range -128 to 127;
signal sin:memory_type:=(50,60,69,78,85,92,96,99,100,99,96,92,85,78,69,
60,50,40,31,22,15,8,4,1,0,1,4,8,15,22,31,40);
begin
process(clk)
begin
if rising_edge(clk)
then
dataout<=sin(i);
i<=i+1;
if(i=31)
then
i<=0;
end if;
end if;
end process;
end arch_sine;
The testbench created by Altera-Modelsim is-
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY lineartau_1_vhd_vec_tst IS
END lineartau_1_vhd_vec_tst;
ARCHITECTURE lineartau_1_arch OF lineartau_1_vhd_vec_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC;
SIGNAL dataout : STD_LOGIC_VECTOR(7 DOWNTO 0);
COMPONENT lineartau_1
PORT (
clk : IN STD_LOGIC;
dataout : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
BEGIN
i1 : lineartau_1
PORT MAP (
-- list connections between master ports and signals
clk => clk,
dataout => dataout
-- clk
t_prcs_clk: PROCESS
BEGIN
LOOP
clk <= '0';
WAIT FOR 500000 ps;
clk <= '1';
WAIT FOR 500000 ps;
IF (NOW >= 50000000 ps) THEN WAIT; END IF;
END LOOP;
END PROCESS t_prcs_clk;
END lineartau_1_arch;
I have defined dataout as an integer but still the testbench is defining it as a std_logic_vector.
Please help resolve this problem
  • sstrell's avatar
    sstrell
    Where is the testbench coming from? Just edit it to change dataout to an integer type.
  • Vicky1's avatar
    Vicky1
    Test bench is generated using "Start Test Bench Template Writer" and its template so in this case it needs to be edited like below,
    SIGNAL dataout : integer range -128 to 127; -- at signals
    dataout : OUT integer range -128 to 127 --- at COMPONENT lineartau_1
    Best Regards
    Vikas Jathar
  • Vicky1's avatar
    Vicky1
    Are you able to do simulation?
    Best Regards
    Vikas Jathar
