NSona1
8 years agoFatal: (vsim-3807) Types do not match between component and entity for port "dataout".
The error shown is- The following is the error shown ** Fatal: (vsim-3807) Types do not match between component and entity for port "dataout". # Time: 0 ps Iteration: 0 Instance: /lineartau_1_vhd...
Vicky1
8 years agoHi,
Test bench is generated using "Start Test Bench Template Writer" and its template so in this case it needs to be edited like below,
SIGNAL dataout : integer range -128 to 127; -- at signals
dataout : OUT integer range -128 to 127 --- at COMPONENT lineartau_1
Best Regards
Vikas Jathar
