Fatal Error: Segment Violation at (nil)
- 3 years ago
From the latest update from the engineering team:
They found the line that's causing the issue:
In vhdl/common_pkg.vhd, the definition of function c_t_char_array_init, if "x(32-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(I, 32));" is commented out, the program will be able to compile successfully.
They were able to resolve the IE with RTL changes and provide the workaround. The two files modified are total.vhd and common_pkg.vhd. Essentially they moved the function declaration from the package to the file where the function is used, which fixed the problem.
Kindly check your email for the workaround. Thanks.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
