Fatal Error: Segment Violation at (nil)
- 3 years ago
From the latest update from the engineering team:
They found the line that's causing the issue:
In vhdl/common_pkg.vhd, the definition of function c_t_char_array_init, if "x(32-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(I, 32));" is commented out, the program will be able to compile successfully.
They were able to resolve the IE with RTL changes and provide the workaround. The two files modified are total.vhd and common_pkg.vhd. Essentially they moved the function declaration from the package to the file where the function is used, which fixed the problem.
Kindly check your email for the workaround. Thanks.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey
Thanks for your reply, I created the archive altho as expected I got the same error message, so not all files are included in the archive.
This was the error message after the archiving:
Project archive created; however, Analysis and Elaboration (or Analysis and Synthesis for export database) was not successful. As a result, some files could not be archived.
Greetings,
Job van Wee
