12 years ago --- Quote Start --- This SRRC filter - did you write it? Have you tried to compile it in isolation? If you compile your components separately you can find the culprit thats causing the slow synthesis and then investigate it. Are the RAMs inferred or are they from the megawizard? --- Quote End --- Hi Tricky, SRRC filter is designed with the help of FIR-mega wizard function , since it is a mega wizard, I have not compiled it in Isolation, all RAMs used by me are from Mega wizard only
