15 years ago
Fast I/O registers in Bidirection IO
Hi, I am trying to improve the IO timing by using fast IO registers.
However, how could I set a proper register when facing a bidirection IO?
Thank you~!
    You have three settings at your disposal:
    FAST_INPUT_REGISTER
    FAST_OUTPUT_REGISTER
    FAST_OUTPUT_ENABLE_REGISTER
    For a bidirectional IO, you can set any or all of these to TRUE for the pin in question. Your design must of course actually support the function:
    1 - The pin must be driven directly by a register output with no combinatorial logic.
    2 - The input must be fed directly to a register with no combinatorial logic
    3 - If you choose to use a fast output enable then the output enable for the pin must be driven directly by a register.
    Jake
    --- Quote Start ---
    --- Quote End ---
    Thank you for your rapidly reply!
    When using a bidirection IO, the output and input are not directly fed by a register, but via a buffer.
    Even if my output reg before bidirection buffer is register pipelined so that there is certainly no combinatorial logic. I think course 1 and 2 are not met because of the buffer itself.
    Only the buffer's enable reg could be set in this condition?
    thank you ag~
    I should be more clear. Besides the buffer ... there can be nothing between the pin and register.
    Jake
    --- Quote Start ---
    Jake
    --- Quote End ---
    I think I've been thinking too much to waht you've said just now, hehe~
    And so according to this, I just set and apply the Fast IO register constrains directly to the Bidir IO pin, it will do work.
    Thank you very much!
