14 years ago
Familly EPF10K on quartus II
Hello everybody;
I was using MaxII +Plus, and when I wanted to make my programme on my CPLD EPF10K-10TC144-4 using my USB port it doesn't work, so I made i search and i found that MaxII plus dont work with USB port, so that's why I downloaded Quartus II web edition.
But I didn't find My CPLD EPF10K-10TC144-4 .
can you please help me?!
    You need to install an older version of Quartus as recent versions have dropped support for that family.
    I think 9.0 is the latest one.
    Thank you!
    I've found this :
    90_quartus_windows.exe
    is that one I need?
    Thank you Probleme Solved!!
    But I have now the probleme of USB blaster! i can't find it !! there is only ethernet blaster on quartus 9.0 ::s
    --- Quote Start ---
    --- Quote End ---
    I use it with 9.0.
    However, I have noticed that the JTAG server crashes when you change Quartus versions. If you close and re-open the programmer window, then run the hardware setup GUI, the USB-Blaster should be listed again. On some occasions I've had to restart Quartus. But in those cases, starting a NIOS IDE shell for the version of Quartus you are trying to use, and typing jtagconfig causes the server to be restarted.
    Cheers,
    Dave
    Ok thank you! now every thing is working weel. but when i want to use the programmer option i don't find .sof .pof ... files :s:s
    --- Quote Start ---
    --- Quote End ---
    You should find a .sof file. That is the SRAM download file.
    Check for messages from the tool. Perhaps synthesis is not running until completion.
    Cheers,
    Dave
    I've juste download the Licence, and now everything is working good :)
    thank's for everyone.
