14 years ago --- Quote Start --- But I have now the probleme of USB blaster! i can't find it !! --- Quote End --- I use it with 9.0. However, I have noticed that the JTAG server crashes when you change Quartus versions. If you close and re-open the programmer window, then run the hardware setup GUI, the USB-Blaster should be listed again. On some occasions I've had to restart Quartus. But in those cases, starting a NIOS IDE shell for the version of Quartus you are trying to use, and typing jtagconfig causes the server to be restarted. Cheers, Dave
