Failure for initialization ROM memory by using $readmemh task
I initialized my ROM memory (instr_mem) by using the $readmemh task. The ROM was successfully complied and simulated, but the waveform show 32'hxxxxxxxx in instr_mem. It seems the 'instr_mem' didn't get the value from mem_instruction.txt file.
module mips_mem(addr1,data_in1,data_out1,we1, addr2,data_in2,data_out2,we2, rst_b,clk); // Boundaries and lengths of each segment // Note that '_top' addresses off by one; the actual top is one less // than the values below. // '_w' values are word addresses input rst_b; input clk; // Inputs and ouptuts: Port 1 input [5:0] addr1; // Memory address input [31:0] data_in1; // Memory write data output [31:0] data_out1; // Memory read data reg [31:0] data_out1; input [0:3] we1; // Write enable (active high; 1 bit per byte) // Inputs and outputs: Port 2 input [5:0] addr2; // Memory address input [31:0] data_in2; // Memory write data output [31:0] data_out2; // Memory read data reg [31:0] data_out2; input [0:3] we2; // Write enable (active high; 1 bit per byte) o // Memory segments reg [31:0] data_mem[0:63]; reg [31:0] instr_mem[0:63]; // Verilog implementation stuff integer i; wire [31:0] write_mask1 = {we1[3], we1[3], we1[3], we1[3], we1[3], we1[3], we1[3], we1[3], we1[2], we1[2], we1[2], we1[2], we1[2], we1[2], we1[2], we1[2], we1[1], we1[1], we1[1], we1[1], we1[1], we1[1], we1[1], we1[1], we1[0], we1[0], we1[0], we1[0], we1[0], we1[0], we1[0], we1[0]}; // Handle Port 1 Read initial begin $readmemh("mem_instruction.txt", instr_mem); end always @(posedge clk or negedge rst_b) begin if(rst_b==1'b0) begin data_out1 <= 32'hxxxxxxxx; end else begin data_out1 <=instr_mem[addr1]; end end endmodule
- ak6dn
You need to provide a lot more context.
What version of Quartus?
What simulator and version?
Show the contents (at least some lines, not all) of your memory init file.
In your waveform display, can you add other signals like addr1[5:0]?
BTW you can collapse the data bit display, no need to show individual bits.
- Kun_Digital_Design
Quartus Prime # Version 20.1.1
mem_Instruction.txt
2402000a 24080005 2509012c 240a01f4 254b0022 256b002d 0000000c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000The screenshot of waveform of addr1[5:0] signal
I did the RTL simulation.
I printed out the content of mem_instr by using $display. The mem_instruction.txt seems successfully included in the design.
What version of Quartus? Quartus Prime # Version 20.1.1
2402000a 24080005 2509012c 240a01f4 254b0022 256b002d 0000000c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000In your waveform display, can you add other signals like addr1[5:0]?
- RichardT_altera
Could you share the design .qar files and testbench so I can try to duplicate the issue from my side?
The mips_mem is the part of the MIPS processor design. The testbench was used to test hold processor,
// Top module for the MIPS processor core // NOT synthesizable Verilog! `timescale 1ns/100ps module testbench; reg [31:0] i; reg [29:0] addr; reg rst_b; wire halted; //parameter parameter start = 0, halfPeriod = 50; reg clk; // The clock initial clk = start; always #halfPeriod clk = ~clk; // The mips_top core mips_top inst_mips(.clk(clk), .rst_b(rst_b), .halted(halted)); initial begin rst_b = 0; #75; rst_b <= 1; end always @(halted) begin #0; if(halted === 1'b1) $finish; end endmoduleHi, I attached the design .qar file to this post.
- RichardT_altera
I am checking on your design. Will let you know if any finding.
- RichardT_altera
The $readmemh does work with Quartus. I suspecting design coding style.
Could you try to integrate the Quartus ROM template in your design?
Right click on any design file -> Insert template -> Verilog/VHDL -> RAMs and ROMs -> Dual Port ROM.
I have integrated a Quartus dual port ram template in my design. It still doesn't work. I used the RTL simulation to generate the waveform. The waveform of ram instantiation still shows 32'bxxxxxxxxxxxxxxxx.
- RichardT_altera
Any update/progress in this case? Do you need further help?
- RichardT_altera
Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
