8 years agoFails trying to install Quartus prime on ARCH LINUX
Cannot install either thru AUR or from .tar -file provided on webpage.
Error messages: https://imgur.com/a/sxuwp I'm new to this board and if the thread is misplaced, I would appriciate if a moderator could move it! Thanks Sixtenson6 Replies
Hi ... could you give exact details of the Arch system? Regards, Jonathan.
All linux versions are not created equal. If you want to run Quartus on linux, best to choose one of the supported versions as listed on the Quartus web page.
--- Quote Start --- Hi ... could you give exact details of the Arch system? Regards, Jonathan. --- Quote End --- Of course! OS: Arch Linux Kernel: x86_64 Linux 4.15.2-1-ARCH Shell: bash 4.4.19 DE: GNOME CPU: Intel Core i7-7500U @ 4x 3.5GHz GPU: intel I have tried downloading from Alteras webpage, but I get an error message about a conflicting lib file right at the end, so I can't start the program... Best regards Sixtenson - Altera_Forum
Hi ...
Having done quite a lot of Quartus command line installation on Ubuntu (and a little on Red Hat) I thought I'd try on Arch. It appears to get itself into some sort of loop and won't complete. As others have said, I'd recommend trying one of the supported Linux platforms. Sorry nothing more positive to report! Regards, Jonathan. Uname says
Installation command wasLinux archlinux 4.14.15-1-ARCH# 1 SMP PREEMPT Tue Jan 23 21:49:25 UTC 2018 x86_64 GNU/Linux./tmp.installquartus.sh/unpack.16.1.0.196/components/QuartusLiteSetup-16.1.0.196-linux.run --mode unattended --unattendedmodeui none --installdir /home/archlinux/altera/ - Altera_Forum
--- Quote Start --- All linux versions are not created equal. If you want to run Quartus on linux, best to choose one of the supported versions as listed on the Quartus web page. --- Quote End --- Thanks for the reply, but I cant get any version to work, sadly. --- Quote Start --- Sorry nothing more positive to report! --- Quote End --- Thanks for trying! - eaw
I’ve also had issues with the installer hanging… but I was able to work around this by installing Quartus Prime Lite and Model Sim separately (using the provided installers in the
folder). So maybe the following might work for you, or perhaps provide more debug output than the GUI installers that just hang.componentsBefore installing, I created the final install directory manually (just in case the installer complained about the directories not already being there):
$ mkdir -p "/home/${USER}/altera_lite/16.0/"Now, go to the setup directory (contains
), enter thesetup.sh
directory, and try running the installers there separately, and without any GUI, as shown below (make sure to change the version numbers as appropriate):components$ cd components $ ./QuartusLiteSetup-16.0.0.211-linux.run --mode text \ --disable-components quartus_help,modelsim_ase,modelsim_ae \ --installdir "/home/${USER}/altera_lite/16.0/"; $ ./ModelSimSetup-16.0.0.211-linux.run --mode text \ --installdir "/home/${USER}/altera_lite/16.0/" \ --modelsim_edition modelsim_ase;Hope this helps someone out!
