8 years agoFails trying to install Quartus prime on ARCH LINUX
Cannot install either thru AUR or from .tar -file provided on webpage. Error messages: https://imgur.com/a/sxuwp I'm new to this board and if the thread is misplaced, I would appriciat...
eaw
5 years agoI’ve also had issues with the installer hanging… but I was able to work around this by installing Quartus Prime Lite and Model Sim separately (using the provided installers in the
components folder). So maybe the following might work for you, or perhaps provide more debug output than the GUI installers that just hang.
Before installing, I created the final install directory manually (just in case the installer complained about the directories not already being there):
$ mkdir -p "/home/${USER}/altera_lite/16.0/"
Now, go to the setup directory (contains
setup.sh), enter the components directory, and try running the installers there separately, and without any GUI, as shown below (make sure to change the version numbers as appropriate):
$ cd components $ ./QuartusLiteSetup-16.0.0.211-linux.run --mode text \ --disable-components quartus_help,modelsim_ase,modelsim_ae \ --installdir "/home/${USER}/altera_lite/16.0/"; $ ./ModelSimSetup-16.0.0.211-linux.run --mode text \ --installdir "/home/${USER}/altera_lite/16.0/" \ --modelsim_edition modelsim_ase;
Hope this helps someone out!
