14 years ago --- Quote Start --- I suspect the reason is using Quartus Web Edition, because: 1. Implementing the project with VHD file is O.K 2. I got a warning: "Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature." but I did not use directly this feature I suspect that using VQM file force you to use this feature. 3. I got a warning: "Port Connectivity Checks…Declared by entity but not connected by instance. Logic that only feeds a dangling port will be removed. ;" But I did and I use the same declaration in VHD file case. You are gently requested to confirm or to reject my assumption. Best regards, Rami --- Quote End --- Hi Rami, it looks like that my last reply is not send out. It looks to me tha tyour problem is related to point 3. Have look to the part in your design where you are using the instance. Are all ports well connected ? Kind regards GPK
