14 years agoI suspect the reason is using Quartus Web Edition, because:
1. Implementing the project with VHD file is O.K 2. I got a warning: "Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature." but I did not use directly this feature I suspect that using VQM file force you to use this feature. 3. I got a warning: "Port Connectivity Checks…Declared by entity but not connected by instance. Logic that only feeds a dangling port will be removed. ;" But I did and I use the same declaration in VHD file case. You are gently requested to confirm or to reject my assumption. Best regards, Rami
