14 years ago --- Quote Start --- Using Modelsim-Altera Starter edition I failed to simulate project that contains VQM file. All output signals from VQM file are drawn red U (undefined). This happened when performing from Quartus II 10.1sp1 Web Edition: Tools => Run EDA simulation tool => EDA RTL simulation Best regards, Rami --- Quote End --- Hi, there are serveral reasons for getting undefined signals. Did you try an RTL simulation upfront ? Do you get warning about timinf violations during the simulation of the VQM file ? Did you have a reset implemented in your design ? Another reason could be that parts of your logic is removed by the synthesis tool. Have a look to the result files of the Quartus run. Kind regards GPK
