14 years ago --- Quote Start --- Synthesizing 99K LEs should take an hour or two. If something was difficult, maybe double that. There is no way it should take a day. If it's due to reductions, you want it to do that because the design would most likely be many times larger(if that's the problem). As recommended, start making sub-projects of smaller hierarchies and benchmark those(synthesis times, how large they are, etc.) and see if there is a problem area. If you can send the design, might be worth a Service Request with Altera. --- Quote End --- I have discovered that there is one part of the design that took up a very long synthesizing time. It involved 6 * 1681 amount of small submodules. any advice on this?
