14 years ago --- Quote Start --- Hi, Long elaboration and synthesis runs could have a lot of reasons. Failure in routing could be caused by different reasons. Which design language are you using ? I would try to setup test projects for each main block of your toplevel, in order to find out which block causes the long runs. Kind regards GPK --- Quote End --- thanks alot! i would really appreciate your help! im using VHDL
