14 years ago --- Quote Start --- Im using Cyclone III EP3C120F780I7. under what circumstances the code will be hard to synthesize? will that lead to failure in routing the signals? --- Quote End --- Hi, Long elaboration and synthesis runs could have a lot of reasons. Failure in routing could be caused by different reasons. Which design language are you using ? I would try to setup test projects for each main block of your toplevel, in order to find out which block causes the long runs. Kind regards GPK
