Failed to create SystemVerilog interface in _hw.tcl in Platform Designer
- 3 years ago
Hi Chunxi,
Done testing. Yes, the top-level port feature that you want can be done by Pro version hw.tcl SystemVerilog interface command.
I had checked internally that this feature only be implemented starting from Pro version 17.1. That's why you'll see package require -exact qsys 17.1 in both the Standard and Pro example given https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/declaring-systemverilog-interfaces-in-hw-tcl.html and https://www.intel.com/content/www/us/en/docs/programmable/683609/22-4/declaring-systemverilog-interfaces-in-hw-tcl.html
If you check the hw.tcl generated by latest Standard version 22.1.2, you'll see it still use this package require -exact qsys 16.1. Means that Standard version not yet supports this feature and document mistake (I'll report this to internal team). Probably this feature will be supported in future Standard release.
So for now, have to stick with traditional method (SV interface used inside the RTL) for Standard version.
Sheng
Did you try putting quotes around "lib/intf/axi4_io.sv"? The screenshot you posted has quotes around the path.
