SKon1
7 years agoExporting an Avalon - MM bus that connects 2 QSYS components.
Hello, Inside QSYS I have 2 components interconnected via Avalon MM: Component A is an Avalon MM master. Component B is an Avalon MM slave. I want to export the Avalon bus signals out of QSYS and...
sstrell
7 years agoSo are you saying that C is basically monitoring what's going on between A and B and you want C to see the addressing being done by A? If B is a custom component, I think the easiest thing to do would be to add outputs from B and export them as a conduit, which I think is what you suggested originally.
#iwork4intel
