SKon1
7 years agoExporting an Avalon - MM bus that connects 2 QSYS components.
Hello, Inside QSYS I have 2 components interconnected via Avalon MM: Component A is an Avalon MM master. Component B is an Avalon MM slave. I want to export the Avalon bus signals out of QSYS and...
sstrell
7 years agoThe easiest way to use an interface both inside and outside a Platform Designer system is to use a pipeline bridge component added to your system design. It has a master interface on one side and a slave interface on the other. Connect one side or the other to components A or B and then export the other side. You can configure the bridge to act as "just wires" or as a true pipeline register, which can help with timing.
#iwork4intel
