SKon1
7 years agoExporting an Avalon - MM bus that connects 2 QSYS components.
Hello, Inside QSYS I have 2 components interconnected via Avalon MM: Component A is an Avalon MM master. Component B is an Avalon MM slave. I want to export the Avalon bus signals out of QSYS and...
KennyT_altera
7 years agoYou mention the correct way, after click on the export button in the qsys. You can use the wrapper to connect out those port to your component C.
