DZuck1
7 years agoExport Multiple Avalon-mm slave interfaces as one interface
Hi, I am trying to use the DisplayPort Intel® Stratix 10 FPGA IP Design Example on a Stratix 10 SX device. The design example has a NIOS processor controlling the different Avalon-mm slaves. I have ...
sstrell
7 years agoYou shouldn't need to export anything. Connect the H2F bridge (master) to all the FPGA slaves you need to control. You can do this by clicking the appropriate dots in the Connections panel or by right-clicking the master interface, going to the Connections submenu, and selecting the slave interfaces to connect to.
Or are you saying you need to connect to parts of your design outside of the Platform Designer system?
#iwork4intel
- DZuck17 years ago
The ARM HPS is in one QSYS design with the H2F bridge exported and the DisplayPort sample design is in another project. Can I connect all of the slaves to an Avalon-mm bridge and export the s0 port from it? I would need to adjust the address range to make sure I can handle all the Avalon-mm slaves.
