Experiencing Quartus unexpected error when compiling a partially reconfigurable design
Hi Arslan,
Thank you for your answer.
First, just to keep you informed my project is not working either with Quartus 18.1 Pro (done following AN797). The compilation of any of the persona is crashing without any explicit error message.
I am totally agree with you, since "blinking_led" is working with Quartus 17.1 & Quartus 18.1 something in my project is making the compilation to crash.
I have already disabled the NIOS debug port since we cannot have JTAG controller in the partially reconfigurable partition (unless using a dedicated bridge). Also, no device PIN is directly connected to the reconfigurable partition as specified in application notes & user guides.
I have also tried to only put dummy logic into the partition (entity inputs are registered and redirected to entity outputs) but it is not working either.
For the moment, I suspect that the DDR3 controller core is maybe the reason of these crashes. I'll try to compile my project without this core and I will keep you informed.
Any help from your part will be much appreciated.
Best regards
