rdruyer
7 years agoExperiencing Quartus unexpected error when compiling a partially reconfigurable design
Hi, We are experiencing an unexpected error with Quartus when compiling a partially reconfigurable custom design for ARRIA 10. First, we successfully followed the Altera AN770. We are able to parti...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
Yes please follow the latest flow you may refer to application note AN797 for that.
https://www.intel.com/content/altera-www/global/en_us/index/documentation/ihj1482170009390.html
Since you have already tested the LEd blinking example, I suspect this is something to do with you design (PR Partition)
Can you check if you disable the NIOS debug port ?
Arslan
