rdruyer
7 years agoExperiencing Quartus unexpected error when compiling a partially reconfigurable design
Hi, We are experiencing an unexpected error with Quartus when compiling a partially reconfigurable custom design for ARRIA 10. First, we successfully followed the Altera AN770. We are able to parti...
PLe_Q1
7 years agoThanks for you answer, you can find the .tcl file into the project archive directory : DDR3_RECONFIG/top/place_route/a10_partial_reconf/
I have only modified the "setup.tcl" following the AN770 guideline.
"flow.tcl" script is untouched since its generation with the NIOS 2 SHELL command "quartus_sh --write_flow_template -flow a10_partial_reconfig"
As you suggested, I've tried to execute the script from the NIOS 2 SHELL after exiting Quartus but it doesn't still the issue. I continue to investigate about these errors and I'll keep you in touch if I find any solution.
