14 years ago --- Quote Start --- the function approach worked out nicely as I had noted. --- Quote End --- Great! But as I commented, beware calling complex functions inside a process, since the function calls will get executed every time the process runs. If the function is just being used to initialize a std_logic_vector, then perform that initialization outside the process. Its a subtle issue, but it makes simulation significantly faster. Synthesis is identical for both methods. Cheers, Dave
