expand On-chip memory
- 3 years ago
Check the links below:
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/NIOS-II/m-p/1290675
This seems like the M9Ks is not being used efficiently. Any bits or memory space that cannot be mapped will then be wasted.
ACTION: Select a larger device or make sure that no interaction problems occur between RAM due to assignments made to the design. Also make sure that all RAM are assigned the correct address and control signals.
You may adjust the on-chip memory Slave S1 Data width so that M9Ks can be mapped properly and being used efficiently. For example, check the design file attached. With Total Memory Size of 41000 bytes (M9Ks 62 / 66 ( 94 % )), the ram can be placed successfully by using Slave S1 Data width of 8 and 64 bits but fail with 16, 32, 128, 256, 512, 1024 bits.
Also, you can expand Error (170040) and check for Info (170034) to see the current design requires how many more memory locations of type M9K to successfully fit. May also check the RAM Summary located in Fitter -> Resource Section.
Sheng
Sheng
- KenNakajima3 years ago
Mr. Sheng
Thank you so much.
I'll try it.
Best Regards.
Kenichi.
