LEDN
3 years agoexample transfer 50mhz to hz
an you give couple example and explain how can you do it I want to convert 50mhz to 9000hz Given CLOCK_50 = 50mhz ( in pin planner) I want to convert by using something like this Example ...
Nurina
3 years agoHello,
We do not receive any response from you on the previous reply provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
P/S: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
