example transfer 50mhz to hz
Well, 50MHz is not an integral multiple of 9KHz, so the question is how close do you need to be?
1) You could just divide 50,000,000 Hz by 5,556 and get 8999.28Hz. That is within 0.008%.
2) If you need to get to exactly 9,000Hz, then you need to use a PLL to do a multiply by 9.
So 9*50MHz is 450MHz, divided by 50,000 is exactly 9,000Hz.
Depends on your exact requirement.
- LEDN3 years ago
maybe we have wrong idea.
my idea is i want to understand the code in the always @ (posedge CLOCK_50) begin.
For example i wrote this codemodule Convert(CLOCK_50);
input CLOCK_50;
reg [ 25: 0 ] Q;
reg CLOCK = 0;
if (Q == 25000000 ) begin
Q <= 0;
CLOCK = !CLOCK ;
end
else
Q <= QQ + 1;
endSo i have reg [25:0] Q. is this Q is 25 bit???
if(Q==25000000) // is if Q == 25bit then the CLOCK = 1 hz? or 1mhz ? i dont know .
This main question i have to understand in this alway @(posedge clock_50) begin clock_50 = 50mhz.
i want to understand how the code work in here. if i want to get 50000000/9000 = 5555.5 or 5556
so if i want to get 9000 then i ran
If(Q==5556)
Q<=0CLOCK <=1; // this is now clock == 9000hz?
- ak6dn3 years ago
First a reg [25:0] value is a 26 bit binary number, and can have a value between 0 and 2^26-1, or 67,108,863.
@(posedge clock_50) is going to toggle every 20ns (assuming a 50MHz clock input). So each count will be 20ns.
5556 * 20ns will be 111.12usec, or 8999.28 KHz.
Do you have access to a graphical verilog simulator as part of your Quartus install? That may make it easier for you to understand.
