JClar
7 years agoExample of a simple Custom IP interface using platform designer similar to interface to user logic component.
I wish to create an interface between NIOS as an (avalon register slave) and an external chip that requires a chipselect_n, read_n line, write_n line, 8 data bits. Many years ago we used SOPC custom...
sstrell
7 years agoIt sounds like you're trying to access an external tristate bus. You can use the generic tri-state controller and Avalon to tri-state bridge components to access it. The Nios would be the master, not the slave. You don't need a custom component to do this.
