JClar
7 years agoExample of a simple Custom IP interface using platform designer similar to interface to user logic component.
I wish to create an interface between NIOS as an (avalon register slave) and an external chip that requires a chipselect_n, read_n line, write_n line, 8 data bits. Many years ago we used SOPC custom...
JClar
7 years agoAnand,
Thank-you for your answer. It is helpful to describe the basic tools to create a project but that was not the question I asked.
Let me try again.
I need to create a custom IP that will give me a CS_n signal, Rd, Wr, and data bus signals using platform designer custom IP tool. I assume using a conduit interface.
Is there a document that describes the signals & interface tab? It states <add signal> and an asterisk. (*).
I assume the names are writeline, readline, etc. Where is a description of these signals and how do I select the correct name?
Jack
