I've compiled the following verilog file:
220model.v , altera_primitives.v, cycloneii_atoms.v and altera_mf.v I've named it as 220model, primitives, cycloneii, altera_mf respectively in modelsim. I havn't compiled the .vhd files, is this the root cause?? - Altera_Forum
how are you running ModelSim? i expect the .do file is compiling those libraries, so you could just comment those lines out
--- Quote Start --- how are you running ModelSim? i expect the .do file is compiling those libraries, so you could just comment those lines out --- Quote End --- Hi, I've chose Modelsim in EDA Tool Settings, and have written the testbench file in NativeLink settings. After compilation I used Tools-> EDA Tool Simulation->Run EDA RTL Sim... i don't know where the do file you've mentioned locates... - Altera_Forum
i don't think 220model.v goes into a library called 220model, check the Quartus II handbook simulation section
seems like NativeLink tries to compile the libraries even though they already exist. i would just comment out the lines where the libraries are compiled in the NativeLink .do file found in simulation/modelsim
