13 years agoI am facing the same problem, I have configured the dual purpose pins as User I/O but i am still getting...
Error (176310): Can't place multiple pins assigned to pin location Pin_12 (IOPAD_X0_Y27_N7) Info (176311): Pin epcs_adso is assigned to pin location Pin_12 (IOPAD_X0_Y27_N7) Info (176311): Pin ~ALTERA_ASDO_DATA1~ is assigned to pin location Pin_12 (IOPAD_X0_Y27_N7) Error (176310): Can't place multiple pins assigned to pin location Pin_14 (IOPAD_X0_Y25_N0) Info (176311): Pin epcs_nce is assigned to pin location Pin_14 (IOPAD_X0_Y25_N0) Info (176311): Pin ~ALTERA_FLASH_nCE_nCSO~ is assigned to pin location Pin_14 (IOPAD_X0_Y25_N0) Error (176310): Can't place multiple pins assigned to pin location Pin_23 (IOPAD_X0_Y22_N0) Info (176311): Pin epcs_dclk is assigned to pin location Pin_23 (IOPAD_X0_Y22_N0) Info (176311): Pin ~ALTERA_DCLK~ is assigned to pin location Pin_23 (IOPAD_X0_Y22_N0) Error (176310): Can't place multiple pins assigned to pin location Pin_24 (IOPAD_X0_Y22_N7) Info (176311): Pin epcs_data0 is assigned to pin location Pin_24 (IOPAD_X0_Y22_N7) Info (176311): Pin ~ALTERA_DATA0~ is assigned to pin location Pin_24 (IOPAD_X0_Y22_N7) Info (171121): Fitter preparation operations ending: elapsed time is 00:00:01 Error (171000): Can't fit design in device Error: Quartus II 32-bit Fitter was unsuccessful. 5 errors, 3 warnings Error: Peak virtual memory: 345 megabytes Error: Processing ended: Tue Sep 11 14:56:58 2012 Error: Elapsed time: 00:00:33 Error: Total CPU time (on all processors): 00:00:18 Error (293001): Quartus II Full Compilation was unsuccessful. 7 errors, 987 warnings Please help.
