13 years agoYes. IIRC with the old Cyclones those pins were hidden, but since the Cyclone III (at least) the FPGA programming pins can either be disabled after configuration, or used as regular I/O.
So if you want to access the EPCS from your application, you need to declare those pins as regular I/O after configuration, and connect them to the EPCS controller in SOPC builder/QSys.
