13 years ago --- Quote Start --- If you don't do that then Quartus marks these pins as reserved and you can't use them in the pin planner. --- Quote End --- Daixiwen, Thank you. Is that necassary even if I want to use the pins as EPCS pins? I don't want to use them as general purpose I/O, they will be connected to a serial Flash for FPGA configuration. It seems to me that Quartus should automatically make the connection from the EPCS controller to the reserved EPCS pins and I shouldn't configure them as I/O's. -phil
