errors found while generate project in "nios II build tools for eclipse"
- 3 years ago
Could you try using the Nios II SBT design template, and select the Hello World template. Then, you should regenerate a new BSP to see the mismatch of names come from the new BSP, or you were using the old BSP generated with the wrong name.
Also, what is the FPGA development kit you are using for your project?
Hope this helps.
Thank you.
Regards.
Kelly
Hope this helps.
Thank you.
Regards.
Kelly
- jkmchow3 years ago
Hello Kelly,
I am using DE-10 Lite board.
Good news: The "Hello World" template was used to generate BSP with sysid changed to sysid_qsys, everything worked perfectly without any errors. The elf file was generated and run paired with the hardware design, things went smoothly. The conclusion is that there is something wrong with the given files.
Thank you for your suggestions and support.
Joseph
